Configuring monitor for WSDL
On 9.x LTM we are trying to create monitor that uses “GET /app/xyz/AdminService.wsdl” string. Neither http, nor SOAP template based monitors work. Meanwhile, the following command
curl http://10.xx.xx.xx:24092/app/xyz/AdminService.wsdl
executed on the same LTM generates correct output.
Is there anything special in .wsdl files that LTM doesn’t like ?
Thanks.
If you have a request which generates the response you want, you should be able to configure that as the monitor send string in a custom HTTP monitor. You can use the -v flag to see the headers you’re sending with curl. Then replace new lines with \r\n. Here is an example:
GET /app/xyz/AdminService.wsdl HTTP/1.1
User-Agent: curl/7.16.3 (i686-pc-cygwin) libcurl/7.16.3 OpenSSL/0.9.8g zlib/1.2.3 libssh2/0.15-CVS
Host: 10.xx.xx.xx:24092
Accept: */*
You can probably leave out the user agent header and add a connection header which tells the server to close the connection:
GET /app/xyz/AdminService.wsdl HTTP/1.1\r\nHost: 10.xx.xx.xx:24092\r\nAccept: */*\r\nConnection: close\r\n
Aaron
Thanks a lot Aaron. Your solution worked!
But I got one more question: How would you modify
to support different IPs of pool members?
I tried shortening the line :
GET /app/xyz/AdminService.wsdl HTTP/1.1\r\nHost: 10.xx\r\nConnection: close\r\n
and it works, but I don’t like the fact that port number is now gone.
You can try taking out the host header value and see if the application still parses the request correctly. If the app accepted a request with a host header value of 10.xx, chances are it’s not using the host header for anything anyhow.
GET /app/xyz/AdminService.wsdl HTTP/1.1\r\nHost: \r\nAccept: */*\r\nConnection: close\r\n
Aaron
Thanks Aaron. I used the following string and it worked just fine:
GET /app/hlr/AdminService.wsdl HTTP/1.1\r\nHost:\r\nAccept:\r\nConnection: close\r\n
What was used as the recieve string for this monitor? I tried using text from the WSDL itself or even the 200 OK, but the monitor would fail if any receive string was specified. Any help is appreciated.
Same issue I’m having. SOmeone mentioned to use an external monitor.
