BIG-IP VERSION 13.1.0.6
Afternoon.
The following LTM policy exists to insert security headers into responses when missing. The LTM policy is attached to a VS which performs virtual hosting using another LTM policy to switch the back-end pools depending on incoming header.
A new requirement to remove the X-Content-Type-Options nosniff header for specific sites hosted on this virtual server exists and the LTM policy was adjusted as below to include a request condition against the host isnot header, this however has resulted in unexpected behaviour where-by the header is no longer inserted regardless of whatever site is being requested.
Any ideas?
Code
ltm policy pol-tp-http-header-apply-security-controls-inc-exclusions {
description "Edit headers on response to enable security controls"
last-modified 2019-01-10:14:09:44
requires { http }
rules {
rl-tp-header-insert-x-content-type-options {
actions {
0 {
http-header
response
insert
name X-Content-Type-Options
value nosniff
conditions {
0 {
http-host
host
not
values { site1.example.com site2.example.com }
1 {
http-header
response
not
values { nosniff }
description "Insert the x-content-type-options header set to no sniff"
ordinal 2
