Configuring LTM as transparent Bridge
Hi All,
I’m interested in using the LTM as a rate shaper for a bunch of users, more specifically shaping p2p traffic as outlined in the “Bandwidth Management for Peer-to-Peer” Whitepaper from F5.
I understand the irule and the rate shaping but having a hard time getting it to detect anything other than vlan broadcasts once its placed inline.
Anyone got any information on the vlan / virtual server sertup for this kind of deployment ?
Cheers,
Jarrod.
Hi Jarrod,
Can you post a link to the whitepaper you’re referencing, a copy of the VIP, iRule and pool config you’re testing and any debug log output from /var/log/ltm? You can list the config objects from the bigip.conf or by running ‘b virtual VIP_NAME list’, ‘b rule RULE_NAME list’ and ‘b pool POOL_NAME list’.
Thanks,
Aaron
Hi Aaron,
Please see the information requested, I hope I got everything you wanted.
Whitepaper: http://www.f5.com/pdf/white-papers/rateshaping-wp.pdf
VIP:
virtual fwd_all {
l2 forward
destination any:any
mask 0.0.0.0
rules test_irule
profiles fastL4_udp_rtp {}
vlans Bridge enable
irule (just for logging at this stage):
rule test_irule {
when CLIENT_ACCEPTED {
log “traffic seen from local [IP::local_addr]”
log “traffic seen from client [IP::client_addr]”
VLAN Setup:
vlan Bridge {
tag 4094
interfaces {
1.1
1.2
Debug Log from /var/log/ltm :
Mar 9 08:45:46 local/tmm info tmm[6628]: 01220002:6: Rule test_irule : traffic seen from local 255.255.255.255
Mar 9 08:45:46 local/tmm info tmm[6628]: 01220002:6: Rule test_irule : traffic seen from client 10.1.5.13
Mar 9 08:45:46 local/tmm info tmm[6628]: 01220002:6: Rule test_irule : traffic seen from local 10.1.5.255
Network Diagram (Basic):
Internet router 10.1.5.1
BIGIP (bridging VLAN)
LNS 10.1.5.50
Customer Pool (10.1.20.0)
Cheers,
Jarrod.
