Hi All/DC Experts,
I am confused what I need to enter on this type of authentication.
Actually I already managed to import groups into f5. The problem is I can’t authenticate.
Any suggestion/comments are really appreciated.
Thanks.
-Nat
Normally, you would enter the search expression in SearchFilter to pull out the corresponding data from the LDAP.
We would use this:
(sAMAccountName=%{session.logon.last.username})
in SearchFilter to query the LDAP record where logon username matches the sAMAccountName field in LDAP.
SearchDN is the normally the base DN.
Minn Hi, Thanks for your response. I put the string to both LDAP query and LDAP Auth. Found out that the problem is that BaseDN of the Groups was different. Thanks. -Nat
