configuring f5isapi.dll
I am new to this WMI.
I am trying to integrated F5 and IIS server.I am using 5.1 IIS server. I copied f5isapi.dll to C:/Inetpub/wwwroot/scripts/ and gave teh basic authentication for the dll file.
I did create a WMI monotir and assigned to a pool.
IS my configuration right? Then from here how do i proced.
when i am opening http://localhost/scripts/f5isapi.dll
i am get website under construction.
Rupa, the WMI monitor should be node specific, not pool level. The pool should have dynamic ratio assigned. Use the IIS event monitor to check for authentication errors, as this is the most frequent issue in my experience. Ken
