Configuring Complex Load Balancing Scenario
Hello.
I’m trying to configure a virtual server using an especial load balancing scenario which is driving me crazy.
Specification:
  • 2 clusters with 2 nodes each one.
  • each cluster will be served as active-passive method.
  • each node in the cluster will be served as round robin.
  • when a cluster changes to active, it will keep this status although the initial active cluster change back to up status.
  1. each cluster will be served as active-passive method → solved using priority groups
  2. each node in the cluster will be served as round robin → solved using a RR method in the pool
  3. when a cluster changes to active, it will keep this status although the initial active cluster change back to up status → PROBLEM! I would use persistence, but I have two nodes instead of one :frowning:
I need to configure this using just a single F5.
Any help will be appreciated.
KR, Dario
Are you saying that for example, you want cluster B to remain active even though cluster A may come back “up”?
If that’s the case then i would do something like assign health monitors at a pool member level and i would configure the monitors that get assigned to the members in cluster A so that manual resume is enabled, that way you can return cluster A to being active when you desire.
Or i could have totally misunderstood your requirements :slight_smile:
Actually, I was taking in consideration to use “Manual Resume”, but the point here is that both members of the cluster should work as a single node.
Imagine this scenario from the picture above.
Cluster-A, Node 1 - Passive
Cluster-A, Node 2 - Passive
Cluster-B, Node 3 - Active
Cluster-B, Node 4 - Active
In case of node 4 flapping (down-up), it should be automatically re-enable to help Node 3 to serve the traffic.
If both nodes (3 and 4) would be down at the same time, then the cluster should change from Active to passive:
Cluster-A, Node 1 - Active
Cluster-A, Node 2 - Active
Cluster-B, Node 3 - Passive
Cluster-B, Node 4 - Passive
I guess I cannot get exactly this behaviour using “Manual Resume”…
KR, Dario
KR, Dario
Finally, this is the solution adopted → https://devcentral.f5.com/codeshare/especial-load-balancing-active-pasive-scenario-1199
