Configuring basic access for F5 VPN
Hi
We are testing out APM and would like to set up a VPN. I seem to recall the ability to define a small set of users on the F5 to be able to log in without authenticating against the predefined AAA server list. Does this ability still exist with 11.6 and if so where do I find it?
Thanks!
You can create local users in “Local User DB”
You must create DB Instance and create user in this instance.
In VPE, add LocalDB Auth Box to authenticate on it.
