Folks
Is any one successfully configured the ASM logging for logrhythm SIEM , please share some config sample i am facing issue were ASM sending the logs but SIEM is not understanding the format
cheers snl
Folks
cheers snl
ASM can send logs in any format desired - please consult with LogRhythm documentation to check which format is required and simply configure that in your ASM’s logging profile
Hi snl,
Did you find the answer?
can F5 configure to send the log to logrythm?
Regards,
Ricky Paulus Ginting
