Need help in configuring AOM IP addres
What impact will the below command do? /etc/init.d/network reload --
I need change the AOM ip address. Any idea if I need to take a downtime or will there be any impact when I reload /init.d/network ?
Regards, Parvez
You should only change the address using the supported method, which is detailed here:
If you utilize a different mechanism, there is no guarantee that you will complete all steps necessary to persist your change, there is no guarantee that it will survive upgrades, and there is no guarantee that there will not be unintended side-effects.
that is a good SOL, but i raise your SOL with this SOL:
sol9608: Configuring AOM network access (800, 1600, 3600, 3900, 6900, 89XX, 11000, and 11050 series platforms)
which does provide that mechanism of Parvez as a valid method.
as long as you do that in the AOM part of the F5 and you are no connected via the network to the AOM you can use the safely. be very sure about the IP you configure though. also test a restart as soon as possible, i did experience so odd effects with this.
BTW: why take this away from us F5, i like the method of being able to ssh to your AOM better then now.
