Configuration guide for F5-BIG-VE-LAB-V13
Hi Guys,
I am looking for configuration guide, can some one point me to the correct pdf doc.
I go the appliance running in VM and I am not sure if I need to update the IP address of the 4 nics given to us or use management studio and update the internal Vnet and External VNet. Any pointer is appreciated.
Regards SP
you will find setup guide here (at the bottom) depending on your hypervisor.You need first to setup by virtual console the management port and route with the config shell command (it’s eth0 first nic). then you can access the web gui and create vlans and associate interface and self IPS.
