Configuration Builder for F5 HNV Gateway Provider Plugin (SCVMM 2012 R2)
Problem this snippet solves:
This tool assists in creating the F5 HNV Gateway Provider Plugin configuration file. It also helps to perform the initial connection to BIG-IQ.
It is tested with BIG-IP TMOS 11.5.3, BIG-IQ 4.5, F5 HNV Gateway Provider Plugin build 1.0.0.77 and SCVMM 2012 R2 UR4, it should work fine with any 1.0.0.x Plugin build.
Code :
62665
