ConfigSync on virtual F5
I need help configuring the Configsync
I initially had two virtual F5s running trial 90 day License. I purchased the Lab licenses and installed on the virtual F5s. The license is configured and shows “License Type = Production”. I want to configure active/standby configuration. I have already setup the “device trust” and created the “device group”. But for some reason the devices are not syncing. Active device shows “Changes Pending” and Standby device shows “Not all Devices Synced”.
I have gone through https://support.f5.com/csp/article/K13946troubleshooting and verified all settings.
Output from Active Device:
tmsh show /cm sync-status
CM Sync Status
Color yellow
Status Changes Pending
Mode high-availability
Summary Details
BIGIP-F5-2.w2k16.com: connected
dg_2 (Changes Pending):
  • 1 devices with older configuration
Recommended action: Synchronize this device to group dg_2
Output from Standby Unit
tmsh show cm sync-status
CM::Sync Status
Color red
Status Not All Devices Synced
Summary
Details
BIGIP-F5-1.w2k16.com: connected
dg_2 (Not All Devices Synced)
root@(BIGIP-F5-1)(cfg-sync Changes Pending)(Active)(/Common)(tmos) show /cm device all
CentMgmt Device: BIGIP-F5-1.w2k16.com
Hostname BIGIP-F5-1.w2k16.com
Mgmt Ip 192.168.137.112
Configsync Ip 192.168.93.101
Mirroring IP ::
Mirroring Secondary IP ::
Failover Multicast IP ::
Failover Unicast IP(s) 192.168.93.101
Device HA State active
Device HA Load Capacity 0
Device Current Load Factor 1
Device Next Active Load Factor 0
Time Delta to Local Device (sec) -
CentMgmt::Device: BIGIP-F5-2.w2k16.com
Hostname BIGIP-F5-2.w2k16.com
Mgmt Ip 192.168.137.113
Configsync Ip 192.168.93.102
Mirroring IP 192.168.93.102
Failover Multicast IP 0.0.0.0
Failover Unicast IP(s) management-ip, 192.168.93.102
Device HA State standby
Device Current Load Factor 0
Device Next Active Load Factor 1
Time Delta to Local Device (sec) 0
I have also force the config sync without any sucess tmsh run cm config-sync force-full-load-push to-group dg_2
Any idea what is missing here
The 1st thing I will check is the config sync ip addresses used and see if if the devices can see each other via ping at least from each config sync ip addresses . Check the config sync self ip address If not mistaken in version 12. upwards the default self ip allow configuration is allowed none. you can change it to allow default which includes the config sync port number then test your config sync again. regarding your second question please read the links below very good material from f5 to guide you understanding the f5 HA concepts
Self IPs are pingable , Port are also responding. I have change the Port lockdown to “Allow All”
Hi DTN,
can you run a config load tmsh load sys config from your text based config on both units and then try and run a sync.
tmsh run cm config-sync to-group device-group-failover
Please share the logs while you do it .
I have noticed that on “BIGIP-F5-2.w2k16.com” you have “Mirroring IP 192.168.93.102” which not exist on “BIGIP-F5-1.w2k16.com”, so first i would suggest to disable the mirroring on the device and configure Specific “Connection Mirroring” Per VS. OR, setup the primary mirroring ip “BIGIP-F5-1.w2k16.com” Self IP on both units in the Traffic group & secondary mirroring ip on both units. run this command to see the status of the HA mirror status - tmsh show sys ha-mirror. it should look like this :
On Active Device
Sys::HA Mirror Status
Traffic Group      TMM    Primary  Secondary  Aborts  Overflows  Errors  Buffered  L4 Mirror  L7 Mirror  L7 Failed
traffic-group-1  [0.0]  connected     closed       1          0       0         0          0          104          64
traffic-group-1  [0.1]  connected     closed       1          0       0         0          0          106          58
On Standby Device:
traffic-group-1  [0.0]  connected     closed       1          0       2         0          0          40          0
traffic-group-1  [0.1]  connected     closed       1          0       2         0          0          50          0
Hope it helped, Shiran.
Thanks everyone for trying to help.
The issue is not related to configuration, but the Version 13.x
Refer to DevCentral - An F5 Technical Community
I stared off with Version BIGIP-13.1.0.2-0.0.6, which did not work.
Next I upgraded to BIGIP-13.1.1-0.0.4, which also did not work.
Finally I downgraded to BIGIP-12.1.3.6-0.0.3, which worked.
Hi DTN, I’m glad it’s working now but i have a lot of customers with any 13 versions & all of them are syncing. so, there is some mismatch between version specifically on your devices. Maybe some irule with “()” this kind of Braces ? Just to be sure try to “tmsh load sys config verify” to see errors / warnings. Have a nice upgrade - it should work.
Best Regards, Shiran Cohen.
