Configsync Issue
recently and after upgrading the F5 to version 13.1.0 and during the manual sync I will get the following configsync status from the result in red “NOT ALL DEVICES ARE INSYNC”.
any suggestion how to fixed, or is there any article on how to fix this issue?
thanks alot in advance.
It does mean one or more of the devices in the device group does not contain the most current configuration.
Fix:View the individual synchronization status of each device group member, and then sync the device that has the most current configuration to the device group.
Refer myF5 for more information
Hi Hardi,
Did you try to sync from other member?
Additional, connect to other member then create a fake node “1.1.1.1” then try to synk (overwrite). it will works.
Regards
