[admin@ed2lb2-pro:Standby] ~ csTest.pl --v
Status of daemons:
Warning: BigDB daemon (bigdbd) is not running.
Configsync configuration:
Failover address (Self): 10.1.1.2
Peer IP address: 10.1.1.1
Configsync port: 443
Configsync username: admin
Acceptable time difference: 600 seconds
Configsync auto detect status:
0 - Synchronized
Last change (Self): 12/27/2010 09:08:14 (1293469694)
Peer state is: known
Last change (Peer): 12/27/2010 09:08:44 (1293469724)
Last configsync: 12/27/2010 09:08:44 (1293469724)
Peer update interval: 30 (seconds)
Network connection status:
Local system is listening on configsync port (443).
Ping test to peer 10.1.1.1 succeeded.
Error: SOAP query failed. Ensure the user ID and password are
correct and the Allow Protocol TCP/443 is allowed on the
primary failover address 10.1.1.1.
[admin@ed2lb1-pro:Active] ~ csTest.pl --v
Status of daemons:
Failover address (Self): 10.1.1.1
Peer IP address: 10.1.1.2
3 - Config modified on both systems, manual intervention required
Last change (Self): 12/27/2010 08:48:17 (1293468497)
Last configsync: 12/16/2010 00:22:17 (1292487737)
Ping test to peer 10.1.1.2 succeeded.
SOAP connection test to peer 10.1.1.2 succeeded.
SOAP time difference check:
Within the acceptable range.
Product version test:
Major and minor product versions are identical. The maintenance
versions are different.
The configsync tests completed successfully. You can run this
diagnostic tool on the peer 10.1.1.2 for further information.
[admin@ed2lb2-pro:Standby] ~ bigstart status bigdbd
Service bigdbd has not been added to bigstart.
[admin@ed2lb2-pro:Standby] ~ bigstart start bigbdb
Couldn’t find service: bigbdb
big3d run (pid 3116) 35 days
bigd run (pid 3105) 35 days
-- same output on Active member --
Items that have been ruled out:
- disk space
- versions match
- Port Lockdown settings
- both LTM’s run through a ‘b load’ just fine.
The syncing seems to be working. But from the EM there is alerts of the configsync status.
[admin@ed2lb1-pro:Active] ~ b config sync show
CONFIG SYNC STATUS --
Status 3 - Config modified on both systems, manual intervention required
Last change (Self) 2010-12-27 08:48:17
Last change (Peer) 2010-12-27 09:08:44
Last Configsync 2010-12-16 00:22:17
[admin@ed2lb1-pro:Active] ~ b config sync all
Checking configuration on local system and peer system…
Peer’s IP address: 10.1.1.2
Synchronizing Master Keys…
Saving active configuration…
Configsync Mode: Push
Transferring UCS to peer…
Installing UCS on peer…
Obtaining results of remote configuration installation…
Current configuration backed up to /var/local/ucs/cs_backup.ucs.
Product : BIG-IP
Version : 10.1.0
Hostname: UCS : ed2lb1-prodecomm.ns.dstcorp.net
System: ed2lb2-prodecomm.ns.dstcorp.net
Installing --shared-- configuration on host ed2lb2-prodecomm.ns.dstcorp.net
Installing configuration…
Post-processing…
Reading configuration from /config/low_profile_base.conf.
Reading configuration from /defaults/config_base.conf.
Reading configuration from /config/bigip_sys.conf.
Reading configuration from /config/bigip_base.conf.
Reading configuration from /usr/share/monitors/base_monitors.conf.
Reading configuration from /config/profile_base.conf.
Reading configuration from /config/daemon.conf.
Reading configuration from /config/bigip.conf.
Reading configuration from /config/bigip_local.conf.
Loading the configuration …
Any Ideas?
Thanks!!!
