ConfigSync Inbound Wide IP
When I perform a ConfigSync, I realase that the Inbound Wide IP don’t sync with the second LC, is this a normal behaviour? I have a HA Pair.
Thanks for advance.
Hi JB,
I’d expect the complete shared configuration to be synch’d when you do a config sync between two units. If you’re not seeing this happen, I suggest opening a case with F5 Support to get help troubleshooting the issue.
Aaron
