Config sync for ASM module not impacting other modules
Hello experts,
Need an advice how to properly sync ASM policy/configuration between different devices. I have an environment with a sync-failover cluster consisting of 2 F5 devices in each data centre so in total - 4 devices. Each cluster runs APM, LTM and ASM.
What I want is to configure sync only between clusters for ASM module not impacting other modules. So if I make ASM change on a cluster in 1st DC the change is synced to 2nd DC cluster. All other changes for LTM/APM are synced between devices in the particular DC cluster only - not propagated between clusters in different DCs. Would this be possible? Is there any guide / KB to implement this?
Thanks, Roman
I think it’s not possible, we cannot customize the config sync. If you find a way, please share
I am thinking the same thing. According to this KB I feel like can do it.
[Overview: Synchronizing ASM systems for disaster recovery]
[Enabling ASM synchronization on a Sync-Only device group]
