I’ve had to roll back out test loadbalancers from 11.4 to 11.2.1 HF3.
I’ve manaually updated the config on the first box and this is working just fine.
Doing this for the second one and running the: tmsh load /sys config command once I’ve uploaded the bigip.conf gives the following error:
Loading system configuration...
/defaults/app_template_base.conf
/defaults/config_base.conf
/config/low_profile_base.conf
/defaults/wam_base.conf
/usr/share/monitors/base_monitors.conf
/config/daemon.conf
/config/profile_base.conf
/defaults/fullarmor_gpo_base.conf
/defaults/classification_base.conf
Loading configuration...
/config/bigip_base.conf
/config/bigip_user.conf
/config/bigip.conf
01070712:3: Caught configuration exception (0), Can't load monitor instance for /Common/http:359 - ltm/validation/MonitorRule.cpp, line 1606.
Unexpected Error: Loading configuration process failed.
When I try and just config-sync over it gives the following:
Aug 15 10:19:17 LTM2 notice mcpd[6112]: 01071038:5: 4a:47:49:fe:50:7c:a7:26:35:6c:9e:49:44:46:43:f7:46:ca:23:83
Aug 15 10:19:17 LTM2 notice mcpd[6112]: 01071038:5: Unit key read from the hardware.
Aug 15 10:19:17 LTM2 notice mcpd[6112]: 01071038:5: Loading keys from the file.
Aug 15 10:19:19 LTM2 info mcpd[6112]: 010712e9:6: Resuming log processing at this invocation; held 1 messages.
Aug 15 10:19:19 LTM2 warning mcpd[6112]: 010712e9:4: gtm.checkpendingmonitor is not in BigDB.dat.
Aug 15 10:19:19 LTM2 warning mcpd[6112]: 010712e9:4: tmm.lb.weightedratioenable is not in BigDB.dat.
Aug 15 10:19:19 LTM2 warning mcpd[6112]: 010712e9:4: lacpd.refport.stick is not in BigDB.dat.
Aug 15 10:19:19 LTM2 warning mcpd[6112]: 010712e9:4: systemauth.radiusservicetype is not in BigDB.dat.
Aug 15 10:19:19 LTM2 warning mcpd[6112]: 010712e9:4: dag.tcp.hash is not in BigDB.dat.
Aug 15 10:19:19 LTM2 info mcpd[6112]: 010712e9:6: Per-invocation log rate exceeded; throttling.
Aug 15 10:19:20 LTM2 notice mcpd[6112]: 01070727:5: Pool /Common/PartnerHub_UAT_Func_SSH member /Common/chlorine:22 monitor status up. [ was up for 0hr:0min:1sec ]
Aug 15 10:19:20 LTM2 notice mcpd[6112]: 01070727:5: Pool /Common/PartnerHub_UAT_Func_SSH member /Common/scandium:22 monitor status up. [ was up for 0hr:0min:1sec ]
Aug 15 10:19:20 LTM2 notice mcpd[6112]: 01070638:5: Pool /Common/Zone_Map_pool member /Common/argon9:9101 monitor status forced down. [ was forced down for 0hr:0min:1sec ]
Aug 15 10:19:20 LTM2 notice mcpd[6112]: 01070639:5: Pool /Common/Zone_Map_pool member /Common/helium5:91 session status forced disabled.
Aug 15 10:19:20 LTM2 notice mcpd[6112]: 01070638:5: Pool /Common/Zone_Map_pool member /Common/helium5:91 monitor status forced down. [ was forced down for 0hr:0min:1sec ]
Aug 15 10:19:20 LTM2 err mcpd[6112]: 01070712:3: Caught configuration exception (0), Can't load monitor instance for /Common/http:359 - ltm/validation/MonitorRule.cpp, line 1606.
Aug 15 10:19:21 LTM2 err mcpd[6112]: 01071488:3: Remote transaction for device group /Common/device-group-failover-584c50b71dcd to commit id 118 5912273116538870559 /Common/LTM1.domain.co.uk failed with error 01070712:3: Caught configuration exception (0), Can't load monitor instance for /Common/http:359 - ltm/validation/MonitorRule.cpp, line 1606..
Aug 15 10:19:21 LTM2 notice mcpd[6112]: 01071038:5: 4a:47:49:fe:50:7c:a7:26:35:6c:9e:49:44:46:43:f7:46:ca:23:83
Aug 15 10:19:22 LTM2 notice mcpd[6112]: 01071038:5: 4a:47:49:fe:50:7c:a7:26:35:6c:9e:49:44:46:43:f7:46:ca:23:83
Aug 15 10:19:22 LTM2 notice mcpd[6112]: 01071038:5: Unit key read from the hardware.
Aug 15 10:19:22 LTM2 notice mcpd[6112]: 01071038:5: Loading keys from the file.
Aug 15 10:19:22 LTM2 notice mcpd[6112]: 010714a0:5: Sync of device group /Common/device_trust_group to commit id 118 5912273116547139026 /Common/LTM1.domain.co.uk from device /Common/LTM1.domain.co.uk complete.
Any advice that could be give on this would be hugely appreciated.
Many thanks Anthony
