Config Removal
We just deployed a pair of F5 devices in HA.
Some of the configurations got duplicated on both devices, and the same needs to be removed.
Please suggest what is the way to remove the redundant configuration.
Thanks -gensek
Please suggest what is the way to remove the redundant configuration.doesn’t gui work?
If they are in HA, would you not just delete the irelivant config from one and push a full sync /force to the second?
