We have a relatively simple environment: two data centers, one web server in each, one bigip in each. Basic pool in each office for web servers consists of (a) local web server and (b) other data center virtual server containing the other web server.
So, if local web down --> send to BIGIP in other DC to get serviced.
Recently, however, deployed an MPLS network with a couple of additional routers which has stopped this functionality from working (because I cannot, or do not know, how to get all of those routers to change their default gateway based on a web server failure).
While I could solve this by SNATTING all requests to the web server (the issue is the return path to the customer does not make it out because of incorrect default gateways in all intermediate routers), we use the IP logs for security auditing, etc.
What would be great is if when a external web request gets serviced by BIGIP, if it send the packet to the local web server, it does not SNAT, however, if it needs to send it to the other web server in the 2nd DC, it SNATS.
Being fairly new to iRules, I have no idea how to write this…would love some help…
Indeed, that search tool is very useful and I have been doing some excellent reading, many posts by yourself (Colin), however, I suppose I left off some data:
Client are accessing a VIP of 192.168.199.100, however, the servers themselves are 192.168.197.100 (local) and 192.168.198.100 (remote behind BIGIP in other DC).
So all requests are going to the VIP and I need to make a SNAT decision (using the interface on the BIGIP as the Source-NAT’ed address) based on whether it’s going to the local 197 server or the remote 198 one.
What about
when LB_SELECTED {
if { [IP::addr [IP::remote_addr] equals “192.168.198.100”] } {
While I am not sure how you inserted the HTML link (is it just the commands?), the link you sent sounded exactly like the issue I am having, however, there was no resolution on it! Some very good steps were taken (most of which I repeated on my box), but still not working like we need it to.
Interestingly, I did not get my logs to show the file, either…
The last one I tried was (a) enabling SNAT, (b) lowering the level of rule validation, and (c) applying the rule below
when LB_SELECTED {
if {[IP::addr [IP::remote_addr] equals "192.168.197.0/24"]} {
LB:reselect snat none
log "In LB_SELECTED, using server:"
log [IP::remote_addr]
but still seeing the SNAT (automap) when it selects the local server, 197.100…
Leveraging the LOGs and considering that perhaps my logic is bad (that is, the SNAT may not be failing, but actually just not applying to the condition I set, because the remote_addr variable I am expecting is ACTUALLY something different), I set up this rule:
Where I am coming from 192.168.1.1, what I see in the LOG is:
Rule test_snat : remote_addr: 192.168.1.1
Rule test_snat : local_addr: 192.168.201.100
Rule test_snat : client_addr: 192.168.1.1
TCL error: Rule test_snat - Error: No serverside connection established (line 5) invoked from within "IP::server_addr"
Any reason why nothing is coming back for IP::server_addr? Per discussion thread 4284 (where I picked up these 4 variables), I would have expected the server_addr to be my pool member.
Incidentally, the session does not connect with this rule applied.
I am thinking the issue now, the reason it is still SNATing, is it is not actually falling under the logic.
This is where discussion thread 4686 essentially leaves off…
The reason you’re not seeing anything set for IP::server_addr is just like it says in the rule, there is no server side connection established.
Since you’re logging these variables in the LB_SELECTED event, you are trying to log the server_addr just before the rule makes a connection to the server.
Try changing the event from LB_SELECTED to SERVER_CONNECTED and the variable should be filled out.
when SERVER_CONNECTED {
set client 192.168.1.1
if {[IP::client_addr] == $client} {
log "local_addr: [IP::local_addr]"
log "remote_addr: [IP::remote_addr]"
log "client_addr: [IP::client_addr]"
log "server_addr: [IP::server_addr]"
and submitted command from client and it did not connect (if I remove the irule, it connects okay) and now the log show this:
Dec 9 08:57:28 tmm tmm[703]: 01220001:3: TCL error: Rule test_snat - Error: No connection established IP::client_addr needs an established connection! (line 2) invoked from within "IP::client_addr"
pool test_snat_pool {
min active members 1
monitor all gateway_icmp
member 192.168.197.100:any priority 12
member 192.168.198.100:any priority 5 monitor none
Again, 197 is local, 198 is remote, but right now, with this iRule on the VS, it does not connected. Remove the iRule, connects. Of course, still have not solved the conditional SNAT we desire.
Thanks, F5. I am, at the very least, enjoying the learning process…admittedly, frustrated, but hoping we will get there…
Some other alternatives in the event you can’t get this working.
1) Snat always and insert the client information into a header that you can then extract on your webservers
2) Snat always and log client info on the BigIP and send to a syslog server where the information can be extracted
3) Use another approach with iRules that involves redirects to the other datacenter if the server selected was not local. Insert a cookie with the other datacenter’s server information so the other BigIP will evaluate the cookie and send the connection immediately to that server, circumventing the load balancing decision and avoiding potential redirection loops.
Admittedly, a rookie at this, it’s going to take some learning to figure out how to do any of those!
I appreciate the suggestion.
I am still very interested in getting the correct information passed to begin with, that is, why even deal with inserting header information, etc, when it seems as if we should be able to solve the original issue I posted!
Ok, tried this rule, but do not see anything different in my IIS logs:
log "CLIENT_ADDR added as IP - [IP::client_addr]"
HTTP::header insert client [IP::client_addr]
The connection gets made, the packet gets SNATTED, the correct IP (client) shows up in the /var/log/ltm, but can’t find the 411 in the IIS log (I am logging everything in ISS on that web service).
Still hoping to find some answers on this issue through this forum…I feel like I have exhausted my knowledge, but still have been unable to get this to work…
Assuming you have a pool setup with some servers you want to SNAT on and others you do NOT, and your virtual server is setup to SNAT ALL (in my case, autosnat is setup), then, here is the new iRule:
when LB_SELECTED {
if {[IP::addr [LB::server addr] equals "[insert server in pool you do not want to SNAT for here]"]} {
snat none
From my initial testing, that seems to do the trick!!
I spent a bit of time thrashing about trying to apply this iRule to a forwarding virtual, so I thought it might be worth pointing out some subtle differences in events based on the type of virtual server. The LB_SELECTED event works fine if you need to test a node address before the connection to the node is established, as in the case with a standard virtual server, or other types that actually load balance such as Performance L4. However, this event DOES NOT FIRE on virtual servers of type forwarding (ip).
Since with a forwarding virtual the destination address doesn’t change, you can use the CLIENT_ACCEPTED event and the [IP::local_addr]. For those used to v4.5.x and “forwarding pools” which allowed you to disable SNAT/NAT, the following iRule will help in the transition to v9.
Given a SNAT that translates everything internal-->external, but you want to disable SNAT to certain destination networks:
class NoNATNets {
network 10.30.1.0 mask 255.255.255.0
network 10.30.100.0 mask 255.255.255.0
pool gateway {
member 10.30.1.254:any
member 10.30.1.253:any
snat SNATInternal {
automap
origin 0.0.0.0 mask 0.0.0.0
vlan internal enable
rule DisableSnatWithClass {
when CLIENT_ACCEPTED {
if {[matchclass [IP::local_addr] eq $::NoNATNets]} {
log "Matching NoNAT List, disabling SNAT: [IP::local_addr]"
snat none
forward
log "No Match in NoNAT List, allowing SNAT: [IP::local_addr]"
pool gateway
virtual Outbound {
destination any:any
profile myfastl4
pool gateway
vlans internal enable
It is also worth noting that if you DO use the LB_SELECTED event for load balancing “transparent devices” such as routers or Firewalls, the address values are similar to CLIENT_ACCEPTED, with the addition of LB::selected. Here they are for review:
IP::remote == the client IP
IP::local == The destination IP of the packet (out in the cloud)
LB::server addr == The node selected (the router or firewall)
You are most welcome. I ran out of gas last night, but here are the other (simpler) versions I came up with that may be useful for someone who has forwarding virtuals.
The problem I was actually trying to solve was simply to disable SNAT for a single forwarding Virtual that passed traffic from the internal to external VLAN. The iRule in the previous post allowed me to eliminate the network forwarding virtual altogether and just do it in the wildcard virtual. Anyhow, if you have a network virtual of type forwarding (ip), you can disable SNAT with any of these iRules. The Virtual:
