I have a Portal defined in my BigIP and when i try to access an oracle fusion server, if i use firefox client or chrome seems to work nice, if i try with iexplorer 11 too, but when client is a iexplorer <10 appears a “Internet Explorer cannot display the webpage”. In the /var/log/ltm i could see Compression errors when i try to access througt a iexplorer 10 <=
/var/log/ltm:Aug 5 11:11:33 f5-apm-2 err tmm2[13032]: 01230140:3: RST sent from [VIRTUAL_APM]:24724 to [ORACLEHOST]:443, [0x18faee5:986] Compression error (Connection aborted) /var/log/ltm:Aug 5 11:11:33 f5-apm-2 err tmm2[13032]: 01230140:3: RST sent from [VIRTUAL_APM]:443 to [CLIENT_APM]:56565, [0x18faee5:986] {peer} Compression error (Connection aborted)
(I replaced original, better to understand)
I try to disable compression in the APM with same results, firefox/chrome/iexplorer 11 works and iexplorer <10 doesnt works. Shall i suppouse that Compression on server(oracle) side is making this response?
Any hints?
Thanks in advance,
