complicated connection over time irule
I need to write an irule for use with a single virtual server redirecting traffic to a specific pool based on URI to control traffic in the following ways: 1. limit any public ip addresses to a max of accessing 2 connections per minute with a total of 10 unique connections in one day. 2. Any per ip access attempts more than 3 requests in 10 seconds be black listed. 3. log the above ip addresses in a table allowing admin review and entry removal.
I have been looking through articles and think I have other sources but have not yet had a window to try it in the lab. Any suggestions or links to other articles are greatly appreciated.
only LTM is running on the appliances, TMOS is 11.2
Here are some posts that can give you some ideas how to write up the rile you need
https://devcentral.f5.com/questions/randomly-unpredictable-rate-limiting-using-the-irule-irulesvirtual\_server\_connection\_rate\_limit\_with\_tablesashx
https://devcentral.f5.com/articles/v101-irules-rate-limiting-with-the-table-command
https://devcentral.f5.com/wiki/iRules.HTTP-URI-Request-Limiter.ashx?NoRedirect=1&NS=iRules
I hope this helps,
-=Bhattman=-
