Compatibility between ASM and Appscan
Hi all,
After importing some Appscan scan results I’ve noticed that most of the vulnerabilities can’t be mitigated (automatically) by ASM. Is there any official documentation published where to find what vulnerabilities ASM is able to mitigate?
There is no official list and any official list would very quickly go out of date as both ASM and AppScan are under constant development. You can find instructions for reviewing vulnerabilites that have been imported under the Getting Started guide for ASM.
