Compare two ASM Policies
Knows anyone a a tool besides BigIQ that can compare two ASM Policies?
With a quick search I found nothing.
Hello,
BIG-IP AWAF/ASM module does, Security > Application Security > Security Policies > Policy Diff
regards
Thanks Lidev.
I know this function, but it shows only a differences summary. I need each different setting.
I tested it with 16.1.x
Then consider deploying ASM with AS3 templates as an option to compare the config in real time :slightly_smiling_face:
I do not renember if you do a policy merge if the compare screen showed better the differences.
K6651: Comparing policies using the BIG-IP ASM policy merge feature
It was too easy. On the Policy Differneces Summary Page you can select the rows and then the F5 displays the details.
You see :grin: , policy diff is the key !
Mark you post as solved :wink:
