command line utility to see GTM result with input as LDNS and wideip?
Hello,
Is there a GTM command line utility that would allow me to enter a wideip and an IP address for LDNS to see what result would be returned by the GTM?
I’m aware of this command
geoip_lookup -f /shared/GeoIP/F5GeoIPRegion2.dat 49.136.1.1
…but this simply queries the geoip database, without regard for wideip or topology table.
We are running 11.6.1HF5.
Thanks,
If you’re looking to test your GTM topology load balancing setup take a look at this thread: Testing GTM Topology.
There is no utility/cmd on the GTM itself that allows you to do this.
