Code requirement for Microsoft Exchange 2010
Does BIG-IP Version 9.3.1 58.0 supports Microsoft Exchange 2010. what is the minimum code requirement?
While you can configure everything for that version, the code rev isn’t supported so you’d have to troubleshoot issues on your own.
I would suggest v10 - since that is what the deployment guides are based on.
Hi Ivan,
Why would u even think of running it on such a old TMOS version… :)…atleast bring it to 10.2.3.
May be what I am understanding from you comment is that you have old boxes which has less than 1G memory so in any case 10.x.x version will never get installed … so you may have to stuck with 9.x.x try to get it sort out with some xtra investment.. :)…
So, Exchange 2010 is being implemented here and the LTMs are currently running 9.3.1.
Upgrading the LTMs would be a major project and so the Exchange upgrade cannot drive an F5 upgrade.
Are there any known issues or gotchas anyone can help me with?
I will be load balancing Exchange 2010 with the current F5 version and just asking for advice or wisdom form others that may have done this and found problems.
Thanks!
When u say current F5 version which one are you talking about.?
Knock, knock! Hey, is this thing on?
Hello, Icario5.
If you use the manual configuration tables and instructions in the most-recent guide for BIG-IP version 10.x, you should be able to get most things to work without modification (caveat: we haven’t tested that). Offhand the only thing I can suggest is that you probably shouldn’t implement OneConnect profiles on v9.x because of various NTLM issues; you’ll have to adjust the iRules accordingly to remove the OneConnect and NTLM references. There *may* be some other subtle iRule syntax that’ll need to change, though offhand I can’t think of any of the commands that have changed appreciably that we use for Exchange. That should be about it.
Good luck and let us know if you run into problems.
Thanks for the reply.
Currently working it out.
Almost there.
Only a few things left.
Will post results when completed.
Your advice is sound Mr. Miller.
The white paper for BIP version 10.x Appendix A (Manual Configuration) has all the pertinent information needed to configure for version 9.3.1.
The monitor for port 135 is still something I need to work out as RPC is used for more than Exchange on the servers but configuring three virtual servers with three pools and the necessary adjustments for persistence and such works out fine.
Thanks again for the reply!
Regards, Lawrence
If you look at pages 41-42 in the v11 guide (Where are F5's archived deployment guides? - F5 Technical Articles - DevCentral - An F5 Technical Community), we offer some suggestions on how to beef up the monitoring for RPC Client Access. It’s not a comprehensive solution (we’d probably need to implement at least a partial MAPI client on BIG-IP for that, whcih is no trivial task), but it gets you to the point where EPMAP (135) traffic is never sent to a server where the MAPI and Address book endpoints aren’t up and listening. This only works for static-port configurations, of course.
