cni calico and openshift or kubernet support static routing
Hi
i want to deploy F5 and kubernet used cni calico with static routing
is that static routing support cni calico, i only know only bgp will support
Openshift uses it’s own sdn router CNI and it does not usually need calico CNI. Also by kubernet you mean kubernetes ? If so see https://clouddocs.f5.com/containers/latest/userguide/static-route-support.html
Yes, i want to deployed CIS and kubernetes cni callico and static routing, thanks for your information, i will try to used this config
--static-routing-mode=true
--orchestration-cni=<ovn-k8s/flannel/antrea/cilium-k8s/calico-k8s>
