CLIENTSSL_DATA broken on 11.3? Autodiscover woes...
I am trying to write an iRule to allow an Exchange 2007>2010 migration. We use Lync and it relies on autodiscover.domain.com pointing to a CAS server. I would like to detect the email in the autodiscover request and route it to the appropriate CAS pool ('07 or '10).
As we have APM, I tried with limited success to build it in there (I figured Why Not? It’s already got LDAP/AD) but it became readily apparent the autodiscover calls didn’t like the F5’s HTTP-based responses.
So I moved to iRules and wrote a HTTP_REQUEST version which did seem to trigger *sometimes*, but would not work at all when any APM was tied to the config.
Since this is not really valid HTTP being passed (more like hybrid HTTP/XML/SOAP), I moved on to trying CLIENT_ACCPTED & CLIENT_DATA but that broke the SSL so I moved on to CLIENTSSL_HANDSHAKE & CLIENTSSL_DATA.
Now I’m seeing the situation where even using the example iRule on the wiki doesn’t ever trigger CLIENTSSL_DATA! No matter if I change it to SSL::collect 50 or strip it down just to the log lines.
Ideas?
Here is the iRule:
when CLIENTSSL_HANDSHAKE {
SSL::collect
log local0. “Got SSL collect iRule! getting data…”
when CLIENTSSL_DATA {
log local0. “Got SSL client DATA iRule!”
if { [SSL::payload] contains “a:Mailbox”} {
log local0. “found SSL a:Mailbox!”
set email [findstr [SSL::payload] “” 11 “”]
log local0. $email
SSL::release
Results in only:
Apr 24 16:05:34 lb1 info tmm[14000]: Rule /Common/Autodiscover-2007-2010_tcp : Got SSL collect iRule! getting data…
TIA!
