I want to authenticate via APM a WebAPP but without the AuthForm from the APM in the middle.
So, I want to view directly the WebAPP Login Form but APM should save the cred to the session anyway.
Is that possible to build with an iRule? What do I have to do?
thanx
bb
Can I assume from your request that you want to use the WebApp’s login form, but then capture the credentials in the access policy? If so, you shouldn’t need an iRule at all. Follow this section of the Configuration Guide for Access Policy Manager:
Adding an external logon page
Posted By Kevin Stewart on 04/05/2013 09:53 AM
Hi Kevin
Many thanx for your answer. With this solution you have to insert some code into the external login page. I don’t want to do that.
I’m looking for a solution without touching anything on the logon page itself.
I think the must be something that intercepts the post that is sent to apm.
I know there is a concept called clientless or somehow this way.
Thanx bb
I found this stuff
enable the clientless-mode so that users will not follow 302 used by APM
HTTP::header replace “clientless-mode” 1
On first request we send the 401 basic auth popup
if { [HTTP::header Authorization] eq “” } {
HTTP::respond 401 WWW-Authenticate “Basic realm=\“srv.example.com\”” Connection close
return
Extract the username and password from the Authorization header in order to store them in session variables for APM authentication and SSO to back-end server
set username [HTTP::username]
set password [HTTP::password]
But it does a basic auth first and will logically save the creds in the authorization header.
But I’m lookign for a solution to intercept the form post request.
Any help are kindly appreciated
bb
This is it… Already here
https://devcentral.f5.com/wiki/APM…lSite.ashx
sorry for any inconvenience
