I have setup my F5 LTM 11.4.0 to have a virtual server that is receiving LDAP requests over 636. I have a profile setup with a cert/key for the client communication and a server profile setup with no cert/key (as I will use the cert being served up by the AD resource). I made 2 virtuals technically as I did one manually and the other through the iApp .. both failed.
The client application attempts to connect and get a “unable to connect”. Installed 2 third party tools and get the same type of error messages.
When I setup the F5 LTM to have no cert/key on the client and whistle the transaction through - it works. Even when I use 636 on the server side, it works (appears to rule out the AD cert). However, once I put the client cert/key back in - it fails.
So everything points to either a cert issue or an F5 configuration issue. I’m not sure how to troubleshoot it as the certificate really does look valid. (Correct SAN, Key Usage, SHA1 algorithm, etc.)
Even the tcpdump analysis simply states: SYN/ SYN,ACK/ ACK/ cert exchange/ change cipher spec x3/ ACK/ RST,ACK - Why the hell did it send a reset packet?
You need to assign a cert/key to your SSL server side profile. Otherwise, the LTM won’t re-encrypt the connection toward your LDAP server. You can use the one loaded on your LDAP server and it should work like a champ.
SSL profiles strip off the SSL. By having a cert/key applied to your client SSL profile, but not your server SSL profile essentially means you are terminating the SSL on the LTM and running native LDAP between LTM and your server.
Interesting. So does your LDAP configuration require something special to exist in the SSL? Normally LDAP is pretty flexible about the SSL layer. That said, there is a difference between LDAP and LDAPS besides the SSL layer. I’m assuming that if you point the client directly at the server and make an LDAPS call, it works. And if you disable both the client and server SSL profiles on the VIP (SSL pass through), then that too works with LDAPS. The reason why I make the distinction is because the following are not equivalent:
Ldapsearch is a command line tool you can use on the BIG-IP to test LDAP, and even though the requests are using the same port, the former will work while the latter will not.
Than the F5 closes the connection (RST,ACK) and ltm logs show “SSL Handshake Failed”. The client never gets to the point of attempting to bind to the directory.
We have reproduced this from various clients. The client SSL profile is currently set to the default with a cert/key. The certificate contains the vip FQDN in the CN= field and SubjectAltName. Virtual Server is of type “standard”. Pretty basic really.
I’ll mention as well that when we are connecting to the encrypted service we use ldaps:// and when unencrypted we change the URL to ldap://. We do understand that concept well. Thanks
So is there now just one scenario where it’s failing? If it’s any consolation, I was able to get all of the above scenarios to work with the basic clientssl and serverssl profiles, Win2k8R2, and the “LDAP Admin” tool (http://ldapadmin.org). I would say at this point, if it’s failing in a specific SSL handshake that you open up an SSLDUMP capture and see if that tells you why SSL may be failing.
Today we found the issue and wanted to share it on this thread. The issue appears to be a problem with Microsoft AD. Microsoft AD is not behaving correctly when the client requests a TLS1.2 connection, and the AD LDAP certificate is signed with RSA-SHA256.
If the certificate is signed with RSA-SHA1, no problem with TLS1.2.
Although this is appears to be an AD problem, the solution we implemented was to disable TLS1.2 from the protocol list on the server SSL profile. “!TLS1_2”
Now F5 negotiates over TLS1.1 and everything works.
The reason it was working when we did not decrypt at the F5 was because the client application was negotiating using TLS1.1 all along while the F5 was using TLS1.2 when we enabled the serverssl profile.
On a previous post I mentioned one of the scenario with re-encryption was working when plain text on the client side but after today we think we might of got lost in the dozen test cases we had gone through.
This is my fully functional secureLDAP virtual configuration.
Steps I followed: 1) Requested certificate i.e. SecureLDAP.domain.com from our internal PKI team 2) Uploaded the cert ; thereafter created CLIENTSIDE ssl profile i.e. CLIENTSSL-secureldap 3) Identified Virtual Server IP i.e. 10.1.1.2; Created DNS record matching matching name in the cert 4) Started out by creating NODES of all AD servers 5) Created a Pool with NODES created in previous step 6) Created a virtual Server with IP : 10.1.1.2 Port 636 7) VS type - Standard ; Protocol : TCP ; Rest all default 8) Applied CLIENTSSL-secureLDAP under SSL PROFILE (Client) section 9) SSL PRofile (SERVER) : left empty 10) Source Address Translation : AutoMap 11) Under resources - assigned the POOL of AD servers created earlier.
Therafter downloaded, installed and launched Softerra LDAP Browser (FREE EDITION) Created a new profile with new LDAP name; defined the Bind username with password (IMP Step) First attempted to connection SSL connection check ; connection got refused Second time - attempted with SSL checkbox checked and connection got succeeded.
ltm virtual VS-int-secureLDAP { description “Internal SecureLDAP lookup against AD servers” destination 10.1.1.2:ldaps ip-protocol tcp mask 255.255.255.255 pool POOL-OF-MY-Active-Directory-Servers profiles { CLIENTSSL-secureldap { context clientside } tcp-lan-optimized { } } source 0.0.0.0/0 source-address-translation { type automap } vs-index 130 }
Bug in F5 When configuring LDAPS (Secure LDAP). Please Fix F5 to accept hostname for Secure LDAP server pool connections.
Why it is an issue with F5’s… Microsoft by default creates a cert that uses FQHN on domain controllers. By default in order to connect via LDAPS to Microsoft domain controller you must connect using FQHN, NOT IP. Big F5 only accepts IPs for LDAP which makes secure LDAPS fail to Microsoft Domain Controllers.
Work Around: Add an additional certificate on the Domain controller with IP as subject alternative name?
Hi Guys..can you pls help me with config that i have to do on LDAP VS on F5 to set up all of this…i am failing again & again in that. My client is Webserver connecting to AD via F5 & AD servers are in F5 pool.
@ F5User-LB, please update the BUG ID for this and as per my understanding, let’s say that the ssl certificate has been issued on the name of xyz.com, with it’s IP being 1.2.3.4, you suggest that another certificate be issued for 1.2.3.4 as the name ?
Active Directory Domain controllers use an internal active directory certificate authority. So xyz.local not xyz.com. The domain controller will be named DC01.xyz.local with a private or public IP of 1.2.3.4. Every server joined to Active directory automatically gets an internal certificate. My opinion, most admins are not going to do a public certificate for Active directory. Doesn’t make sense and adds an un-needed level of complexity. The Certificate has Subject alternative name has DC01.xyz.local and no IP address specified. So to do LDAPS, the F5 needs to trust the active directory certificate authority AND accept a hostname of DC01.xyz.local instead of IP address to connect to the domain controller in order to secure LDAP (LDAPS). Because it is connecting with IP address and not hostname, Microsoft decides the connection is insecure and refuses the connection. This is the way I understand it to work after trying to connect with DNS and IP using LDAP testing tools and diving into the errors. You would need to contact Microsoft to get further information. P.S, it has been 2 years, I gave up and found an alternate method to authenticate that worked. Hope this helps you, but I’m not willing to spend more time on it.
Did you ever get an answer on this? I was able to use the iapp (to Microsoft AD) and get it working (for browsing anyway) with client side certificate and server side certificate and without any. But, get some failures from an application trying to change passwords or move users to other OU’s. Just started troubleshooting.
