Hello all, After upgraded LTM from 3600 (TMOS version 10.2) to 2000 (TMOS version 11.5.4). I found that sometime Client may stuck in TCP SYN status. Below is my scenario.
- I created 1 Virtual Server 2.2.2.2:80, enabled Performance L4, SNAT and Source Port “Changed”.
- 2 Clients try to telnet 2.2.2.2 port 80 at the same time
- 1 of the client may got stuck in TCP SYN status. Server did not response SYN ACK or RST
But this case did not happen in TMOS version 10.2 before. To workaround this issue, I changed Performance L4 to standard and the problem resolve. Any idea on this case? please advise. Thanks.
Best way to find out is:
Do tcpdump on BIG-IP - something like
tcpdump -nni -s0 0.0:p host [VS IP]
- not sure if this will work, you can try
tcpdump -nni -s0 0.0:p 'host [client 1 IP] or host [client 2 IP]'
Issue
watch -n 1 tmsh show sys connection cs-server-addr [VS IP]
Then you should see more or less what happens on BIG-IP when two clients are connecting to VS. Sure best option is do that in test environment where you are not processing thousands of connections.
But seems to be kind of bug, because you should get RST after Idle Timeout set TCP profile - except if you have Reset on Timeout disabled in TCP profile.
Piotr
