Client SSL authentication with mutlipe trusted CAs and CRLs
Hello,
we are using a client SSL profile with client authentication enabled. Now I need to add a second trusted CA and CRL. I created a second SSL profile with the new CA/CRL and tried to add it to the virtual server, but I receive following error: Virtual server xyz has more than one clientssl/serverssl profile with same server name. What would be the best way to accomplish this? Thanks in advance!
combine both CA certificates into one certificate bundle (just copy paste the base64 info into one file / text field)
for CRL it is more complicated you will have to merge those, which probably will require some scripting.
btw: similar question with some options was asked here: DevCentral - An F5 Technical Community
in the end you might consider setting up two virtual servers with different hostnames, will make your life easier for sure :slight_smile:
