CLIENT KEY property in iControl/HTTPS Monitor missing
I need to create a HTTPS Monitor on a 9.4.5 LTM box using iControl, however it looks like there is no property in iControl to set the Client Key.
The monitor properties available are listed in iControl Documentation here:
http://devcentral.f5.com/wiki/default.aspx/iControl/LocalLB\_\_Monitor\_\_StrPropertyType.html
As you can see there is a STYPE_CLIENT_CERTIFICATE, but no property named STYPE_CLIENT_KEY or any property to set the Client Key.
Client Key is a relatively new feature which appeared in BIG-IP Web GUI 9.4.2+
F5 guys (Joe, Colin) - can you confirm that this is a problem in iControl?
