Client certificate on server side
we have a requirement wherein, F5 should send a client certificate (this certificate would be imported in F5 LTM) to the backend server. Backend server would validate this certificate and if the certificate is ok then connection would be allowed. is it doable? Thank
Hi, You need to create a server-ssl profile with client certificate and key you want to be used by F5 and then assign that profile to the VIP.
