Client Certificate Authentication Risks
Hi, currently I have a VS which is working on ‘require’ client authentication setting. I have imported the root certificate of client certificate in ‘Trusted Certificate Authorities’ and ‘Advertised Certificate Authorities’. Additionally, we have created two irules, one would validate the serial number of the certificate and other would validate the CN of the certificate. I want to know, is it a good approach? are there any security risks with it? What are some of the things which I can tighten as part of client certificate authentication?
There is no security risk.I would suggest you to combine both irule to single irule. And you have to select CA certificate in Client Authentication cert list. Let us know if you have any question.
Thank you jhaas.
