I am in need of testing an irule as well as a bit of QA. Basically I am trying to not only pull the client address and insert it into a header but at the same time I am trying to direct traffic to an OCSP responder. I have compiled this Irule and need to see if this is workable?
when CLIENT_ACCEPTED {
set tmm_auth_ssl_ocsp_sid 0
set tmm_auth_ssl_ocsp_done 0
when CLIENTSSL_CLIENTCERT {
set ssl_cert [SSL::cert 0]
set client_add [IP::client_addr]
session add uie “msrs_$client_add” $ssl_cert 900
if {$tmm_auth_ssl_ocsp_sid == 0} {
set tmm_auth_ssl_ocsp_sid [AUTH::start pam default_ssl_ocsp]
AUTH::cert_credential $tmm_auth_ssl_ocsp_sid [SSL::cert 0]
AUTH::cert_issuer_credential $tmm_auth_ssl_ocsp_sid [SSL::cert issuer 0]
AUTH::authenticate $tmm_auth_ssl_ocsp_sid
SSL::handshake hold
when CLIENTSSL_HANDSHAKE {
set tmm_auth_ssl_ocsp_done 1
when AUTH_SUCCESS {
if {$tmm_auth_ssl_ocsp_sid eq [AUTH::last_event_session_id]} {
SSL::handshake resume
when AUTH_FAILURE {
reject
when AUTH_WANTCREDENTIAL {
reject
when AUTH_ERROR {
AUTH::abort $tmm_auth_ssl_ocsp_sid
if {$tmm_auth_ssl_ocsp_done == 0} {
reject
if { (! [HTTP::cookie exists ClientZ]) || ([HTTP::cookie value ClientZ] equals “”)} {
set cert [session lookup uie “msrs_$client_add”]
if { $cert ne “” } {
set certStr [X509::whole $cert]
regsub -all “\n” $certStr “” certStr
set certStr [string trimleft $certStr “-----BEGIN CERTIFICATE-----”]
set certStr [string trimright $certStr “-----END CERTIFICATE-----”]
if { $certStr equals “” } {
session delete uie “msrs_$client_add”
set certStr [HTTP::cookie ClientZ]
if { [info exists certStr] } {
if { $certStr ne “” } {
HTTP::header insert SSL-Client-Cert $certStr
when HTTP_RESPONSE {
HTTP::header insert “Set-Cookie ClientZ=$certSTR; Path=/”
