Problem this snippet solves:
This is an example using HTTP cookie for authentication. If authentication is successful, a cookie will be sent to client. If next time, the AUTH cookie is present and valid, client will be passed immediately without being checked with AAA server. The cookie name, password, domain should be properly modified by user. This rule is for radius AUTH. If replacing radius with ldap or tacacs, it works too.
Code :
when CLIENT_ACCEPTED {
set authinsck 0
set forceauth 1
set ckname BIGXAUTH
set ckpass 1xxx5678
set ckvalue [IP::client_addr]
set ckdomain .y.z
set asid [AUTH::start pam default_radius]
if {[HTTP::cookie exists $ckname]} {
HTTP::cookie decrypt $ckname $ckpass 128
if {[HTTP::cookie value $ckname] eq $ckvalue} {
set forceauth 0
HTTP::cookie remove $ckname
if {$forceauth eq 1} {
AUTH::username_credential $asid [HTTP::username]
AUTH::password_credential $asid [HTTP::password]
AUTH::authenticate $asid
HTTP::collect
when HTTP_RESPONSE {
if {$authinsck eq 1} {
HTTP::cookie insert name $ckname value $ckvalue path / domain $ckdomain
HTTP::cookie secure $ckname enable
HTTP::cookie encrypt $ckname $ckpass 128
when AUTH_SUCCESS {
if {$asid eq [AUTH::last_event_session_id]} {
set authinsck 1
HTTP::release
when AUTH_FAILURE {
HTTP::respond 401 "WWW-Authenticate" "Basic realm=\"\""
when AUTH_WANTCREDENTIAL {
when AUTH_ERROR {
HTTP::respond 401
