Clickjacking protection with X-Frame options
We have a situation where sites are missing X-Frame Options How can we return a response header with the name X-Frame-Options and the value DENY to prevent framing altogether, or the value SAMEORIGIN to allow framing only by pages on the same origin as the response itselfSecure Cookies
I found the following single line iRule implementation, can you please verify
when HTTP_RESPONSE { HTTP::header insert “X-FRAME-OPTIONS” “(DENY || SAMEORIGIN)” }
I’d use a replace:
   HTTP::header replace X-Frame-Options "SAMEORIGIN"
Hi Kevin ,
How to test once we have implemented the iRule ?
thanks and regards Deepak MK
Hello Everyone,
That iRule works, however it means that we have to add it to every VS we have (we have tons of those). is there a better solution? does F5 has a HF for it?
