CLI usage
I´m trying to type commands like “tmsh list net self-allow” on a 3400 appliance but the command is not accepted, defining the terminal access as bigpipe shell or tmsh. Can anyone help me with this? I must have to get in other mode but not sure how to do it…
thanks!
First check if you are running with tmsh or not
For Big Pipe please try b self allow if tmsh you can try like this: tmsh hit Enter list net self-allow
i get this error: admin@F5(Active)(tmos) tmsh Syntax Error: unexpected argument “tmsh”
Please try Below only you will get the o/p:
list net self-allow
I get this output:
admin@F5(Active)(tmos) list net self-allow net self-allow { defaults replace-all-with { ospf:any tcp:domain tcp:f5-iquery tcp:https tcp:snmp tcp:ssh udp:520 udp:cap udp:domain udp:f5-iquery udp:snmp } }
thank you.
