CLI command for VIPs without any pools
Hello All,
We are doing a housekeeping activity in our DC and i need a CLI command that can retrieve the list of Virtual IPs that are not associated with any pool.
It would be better if we can get the output as an excel file in /var/tmp folder.
Please help.
Thanks in Advance
[root@LABBIGIP1:Active:Changes Pending] log # tmsh list ltm virtual pool
ltm virtual gre_vs1 {
    pool gre_vs1
ltm virtual vs_without_pool {
    pool none
[root@LABBIGIP1:Active:Changes Pending] log # tmsh list ltm virtual pool | grep "pool none" -B1 | grep ltm | awk '{print $3}'
vs_without_pool
[root@LABBIGIP1:Active:Changes Pending] log # tmsh list ltm virtual pool | grep "pool none" -B1 | grep ltm | awk '{print $3}' > /var/tmp/vs.list
[root@LABBIGIP1:Active:Changes Pending] log # cat /var/tmp/vs.list
vs_without_pool
Thanks a lot. The first command worked. However it is not working when i try to export the output to a file. The file is not getting created.
and ‘awk’ is not supported anymore. I had to replace it with grep.
You can also upload qkview to ihealth , that shows all the orphan objects.
Thank you
