class match hostname in 10.2.1 irule
Guys,
My website www.mycomp.com also has some country specific domain registration addresses. Customers visiting my website on a regional address need to be routed to my .com address and get my website shown.
IMHO, most decent way to do this is to use a data group for this, put in the country specific domain names and match the domain name request against the data group entries and do a redirect.
Implementation:
I’ve created a string type data group named “website_aliases”
Filled it with string/values equal to domainname/pool (pool is not used as an reference but each string needs a value), a couple of examples:
www.mycomp.de pool_mycomp
www.mycomp.fr pool_mycomp
www.mycomp.nl pool_mycomp
The in the irule:
set host [string tolower [HTTP::host]]
set uri [string tolower [HTTP::uri]]
switch -exact $host {
“www.mycomp.com” {
pool pool_mycomp
if {[class match $host equals website_aliases]} {
HTTP::redirect http://www.mycomp.com/ }
Irule is accepted so contains no syntax errors.
Still after synch, when trying in a browser http://www.mycomp.com , it is reinitialised
Any of the aliases also don’t work either so https://www.mycomp.de is not redirected to http://www.mycomp.com
Any ideas?
e.g.
[root@ve1023:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool pool_mycomp
   destination 172.28.19.79:80
   ip protocol 6
   rules myrule
   profiles {
      http {}
      tcp {}
[root@ve1023:Active] config  b class website_aliases list
class website_aliases {
      "www.mycomp.de"
      "www.mycomp.fr"
      "www.mycomp.nl"
[root@ve1023:Active] config  b rule myrule list
rule myrule {
   if { [class match -- [HTTP::host] equals website_aliases] } {
      HTTP::redirect "http://www.mycomp.com"
[root@ve1023:Active] config  curl -I http://www.mycomp.com
HTTP/1.1 200 OK
Date: Wed, 18 Apr 2012 13:21:10 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Fri, 11 Nov 2011 14:48:14 GMT
ETag: "4183e4-3e-9c564780"
Accept-Ranges: bytes
Content-Length: 62
Content-Type: text/html; charset=UTF-8
[root@ve1023:Active] config  curl -I http://www.mycomp.de
HTTP/1.0 302 Found
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
Hmm, in you’re rule you specify an “--” in the class match, why is that?:
Furthermore interesting that you’re setup works…
Thnx,
Michiel
-- Terminates option processing (useful if the or begins with a hyphen).class wiki
your irule is not working since you are not able to mix switch with if-clause likes that.
hope this helps.
