im having an issue getting my hands around this irule:
set pooluri “”
set pooluri [class match -name $originaluri starts_with pool-list]
if {$pooluri eq “”} {
set pooluri “default”
set pooluri2 [class match -value pooluri equals pool-list]
set dest_pool [getfield variable_uri_2 “,” 1]
im not understanding what the -name and -value differences are. is this rule saying if the $originaluri variable starts with an entry in the pool-list class, set the $pooluri variable to ‘default’ .. and if its not in the class list do nothing?
then im really confused on the class match -value statement. what is the difference between -name and -value? ive never used class match in this way, and help decoding this would be much appreciated!
nitass
February 12, 2012, 5:00am
2
e.g.
[root@ve1023:Active] config b class pool-list list
class pool-list {
"string1" { "value1" }
"string2" { "value2" }
"string3" { "value3" }
[root@ve1023:Active] config b rule myrule list
rule myrule {
when RULE_INIT {
log local0. "\[class get pool-list\]: [class get pool-list]"
log local0. "\[class match -- string2 equals pool-list\]: [class match -- string1 equals pool-list]"
log local0. "\[class match -- string2 equals pool-list\]: [class match -name string2 equals pool-list]"
log local0. "\[class match -- string2 equals pool-list\]: [class match -value string2 equals pool-list]"
[root@ve1023:Active] config tail -f /var/log/ltm
Feb 11 21:56:09 local/ve1023 err mcpd[3746]: 01020066:3: The requested rule (myrule) already exists in partition Common.
Feb 11 21:56:10 local/tmm info tmm[4822]: Rule myrule : [class get pool-list]: {string1 value1} {string2 value2} {string3 value3}
Feb 11 21:56:10 local/tmm info tmm[4822]: Rule myrule : [class match -- string2 equals pool-list]: 1
Feb 11 21:56:10 local/tmm info tmm[4822]: Rule myrule : [class match -- string2 equals pool-list]: string2
Feb 11 21:56:10 local/tmm info tmm[4822]: Rule myrule : [class match -- string2 equals pool-list]: value2
thanks! im almost there.
in your example…
log local0. “\[class match -- string2 equals pool-list\]: [class match -name string2 equals pool-list]”
what would be the result if string2 did NOT exist in the class pool-list ?
nitass
February 13, 2012, 1:01am
5
what would be the result if string2 did NOT exist in the class pool-list ?0 will be returned.
class match [options] item operator class
Returns 0 or 1 depending on whether item matches an element in class.class wiki
nitass
February 13, 2012, 1:10am
6
e.g.
Feb 12 18:06:23 local/ve1023 err mcpd[3746]: 01020066:3: The requested rule (myrule) already exists in partition Common.
Feb 12 18:06:23 local/tmm info tmm[4822]: Rule myrule : [class get pool-list]: {string1 value1} {string2 value2} {string3 value3}
Feb 12 18:06:23 local/tmm info tmm[4822]: Rule myrule : [class match -- string9 equals pool-list]: 0
Feb 12 18:06:23 local/tmm info tmm[4822]: Rule myrule : [class match -name string9 equals pool-list]:
Feb 12 18:06:23 local/tmm info tmm[4822]: Rule myrule : [class match -value string9 equals pool-list]:
hoolio
February 13, 2012, 9:18pm
8
As always, nice work in explaining this Nitass!
Aaron
