ClamAV has an FTP’esque protocol in that initial connections are made via a control connection, which then requests a stream port to send the actual files to be scanned on. I’ve written and tested the following iRule, however there might be a few issues with it:
when SERVER_CONNECTED {
log "server connected"
TCP::collect
when SERVER_DATA {
log "server data"
set sdata [TCP::payload]
if { $sdata contains "PORT" } {
set ::clamport [regexp -inline {[0-9]+} [TCP::payload]]
log "I have $::clamport"
listen {
proto 6
timeout 30
bind [LINK::vlan_id] [peer {IP::local_addr}] $::clamport
server [LB::server addr] $::clamport
allow [IP::client_addr]
TCP::release
TCP::collect
This iRule is attached to an internal VS listening on 3310, SNAT automap, round robin load balancing an no persistance profile.
Now, the main issue I can see is that $::clamport is global(assuming my reading of the TCL manual is right), however listen{} doesn’t appear to work with non-global variables. If I simply used $clamport TCL would complain that the variable doesn’t exist.
Any suggestions on improving the iRule? I don’t think speed is hugely important as the control connection is pretty lightweight however the use of globals makes me nervous and I’m hoping that I’ve missed something and listen can be made to work with local variables.
