hi anyone successfully deployed XenMobile with APM? Any pro/con with deploying XenMobile with Netscaler? Thanks for your inputs Alexandre
Are you asking about XenMobile MDM edition or XenMobile Enterprise edition?
XenMobile Enterpride edition. Some Citrix consultant claims that only Netscaler supports Worx (MicroVPN.. which looks to me similar to iOS per-vpn).
Yes, you are right, Citrix MicroVPN/MDX technology is very similar to per-app VPN. It is certainly feasible to use F5 EDGE VPN client with it’s Per-App VPN capabilities and use Worx apps with it.
Hi amolari,
The EDGE Client is required, to build up these tunnels. But as any other Software I assume you could also use the MDM Solution to deploy the EdgeClient as part of the overall setup.
wiesmann
