Citrix ICA proxy solution in F5 LTM
We have established an MPLS connectivity from partner to access the our applications through Citrix Storefront.
Currently we have only port 443 opened at partner firewall for this connectivity which allows only to access the URL and applications are not getting launched after the URL login.
Citrix SME says that we need have an ICA proxy (for ports 2598 & 1494) solution in F5 to get this working
Any suggestion for the same on how to implement.
i recommend downloading the latest iapp template, and deploy your citrix environment using that. Also, make sure you read through the deployment guide, so that you make sure you are deploying it correctly according to your citrix environment:
Thanks Kai M
I’m working on this attached solution but want to ensure that this is the only option for my issue.
