When I look at the documentation for the new iApp for Citrix VDI (v2.1), it says the supported version 11.4.0 to 11.6.0. We are currently running 11.6.4, so does this mean we cannot use the iApp template? I figured it would be fine assuming of course that all iApp versions are tested against the CodeBase.
there is no v11.6.4. It’s v11.6 Hotfix4. So it’s release 11.6. Supported by the Citrix VDI v2.1 iApp.
Thanks!
