Problem this snippet solves:
Contributed by: F5 Solutions Engineering - solutionsfeedback at f5.com
===Description=== With the combination of BIG-IP Access Policy Manager (APM) and Citrix XenApp, organizations can deliver a complete remote access solution that allows for scalability, security, compliance and flexibility.
This iRule comprises the first part of two iRules that are part of the Citrix Secure Access deployment. The complete installation instructions for this setup will be located in the solutions section of F5.com shortly.
With this iRule, users can connect using BIG-IP APM’s secure proxy mode, allowing for connections to XenApp from a variety of clients including Citrix Receiver, PN Agent and Dazzle.
Code :
when RULE_INIT {
set tmm_apm_pnagent_url "/Citrix/PNAgent/config.xml"
when CLIENT_ACCEPTED {
TCP::collect 7
when CLIENT_DATA {
# Disable SSL if it's HTTP CONNECT request
if { [TCP::payload 7] equals "CONNECT" } {
SSL::disable
TCP::release
set tmm_apm_host [HTTP::host]
set tmm_apm_uri_path [HTTP::path]
set tmm_apm_user_agent [HTTP::header "User-Agent"]
set tmm_apm_http_method [HTTP::method]
set tmm_apm_session_id ""
set tmm_apm_citrix_receiver 0
set tmm_apm_citrix_pnagent 0
set tmm_apm_citrix_nongateway 0
set tmm_apm_citrix_ica_patching 0
set tmm_apm_vip "$tmm_apm_host:[TCP::local_port clientside]"
log -noname accesscontrol.local1.debug "01490000<!--:3: Request [HTTP::request]"-->
if { [HTTP::cookie exists "MRHSession"] } {
set tmm_apm_session_id [HTTP::cookie "MRHSession"]
if { $tmm_apm_user_agent contains "CitrixReceiver" } {
set tmm_apm_citrix_receiver 1
} elseif { ($tmm_apm_user_agent contains "PNAMAIN") or
($tmm_apm_user_agent contains "PNAMain") or
($tmm_apm_user_agent contains "pnamain") or
($tmm_apm_user_agent contains "Dazzle") or
($tmm_apm_user_agent contains "Darwin") } {
set tmm_apm_citrix_pnagent 1
if { $tmm_apm_http_method equals "CONNECT" } {
if { ![HTTP::header exists "Proxy-Authorization"] } {
HTTP::respond 407 Proxy-Authenticate "Basic realm=\"123\""
return
set authstr [lindex [ split [HTTP::header "Proxy-Authorization"] " " ] 1 ]
set remainder [lindex [split [expr [string length $authstr] / 4.0 ] "." ] 1]
if { $remainder != "0" } {
if { [regsub -all {(A=)} $authstr = newstring] > 0 } {
set authstr $newstring
set apm_session [ lindex [ split [b64decode $authstr] ":" ] 0 ]
if { ![ACCESS::session exists $apm_session] } {
return
log -noname accesscontrol.local1.debug "01490000<!--:3: Request for citrix resource received from session: $apm_session"-->
ACCESS::disable
use virtual citrix_connect_proxy
if { ($tmm_apm_session_id == "") && ($tmm_apm_citrix_pnagent == 1) } {
HTTP::header insert "clientless-mode" 1
HTTP::header insert "username" ""
HTTP::header insert "password" ""
if { $tmm_apm_uri_path equals $::tmm_apm_pnagent_url } {
ACCESS::disable
return
if { ![info exists tmm_apm_citrix_username] && [HTTP::header exists "Content-Length"] } {
HTTP::collect [HTTP::header Content-Length]
if { $tmm_apm_citrix_receiver == 1 } {
if { $tmm_apm_uri_path starts_with "/Citrix/PNAgent/" } {
ACCESS::disable
return
if { ![info exists tmm_apm_citrix_username] } {
if { [HTTP::header exists "Content-Length"] } {
set tmm_apm_citrix_nongateway 1
HTTP::header insert "username" $tmm_apm_citrix_username
HTTP::header insert "password" $tmm_apm_citrix_password
} elseif { $tmm_apm_uri_path equals "/cgi/login" } {
HTTP::cookie remove MRHSession
} elseif { $tmm_apm_uri_path equals "/ipad" } {
set AD_only "citrixreceiver://createprofile/?s=$tmm_apm_host&pname=Profile-$tmm_apm_host&gw=1&gwt=2&gwa=1"
set RSA_only "citrixreceiver://createprofile/?s=$tmm_apm_host&pname=Profile-$tmm_apm_host&gw=1&gwt=2&gwa=2"
set AD_RSA "citrixreceiver://createprofile/?s=$tmm_apm_host&pname=Profile-$tmm_apm_host&gw=1&gwt=2&gwa=3"
HTTP::respond 200 content "<h2 id="community-284637-toc-hId-1652094348">
<a href='\"$AD_only\"' rel="nofollow noopener noreferrer">Click here for domain only auth</a><a href='\"$RSA_only\"' rel="nofollow noopener noreferrer">Click here for RSA only</a><a href='\"$AD_RSA\"' rel="nofollow noopener noreferrer">Click here for Two-factor auth</a>
</h2>"
when HTTP_REQUEST_DATA {
if { ($tmm_apm_citrix_pnagent != 1) && ($tmm_apm_citrix_receiver != 1) && ($tmm_apm_citrix_nongateway != 1) } {
return
set payload [HTTP::payload]
log -noname accesscontrol.local1.debug "01490000<!--:3: Parsing credentials for Citrix receiver"-->
set tmm_apm_citrix_username ""
set tmm_apm_citrix_password ""
set tmm_apm_citrix_password1 ""
set urlvars [ split $payload "&" ]
foreach {u} $urlvars {
set param [ lindex [ split $u "=" ] 0 ]
set value [ lindex [ split $u "=" ] 1 ]
if { $param equals "login" } {
set tmm_apm_citrix_username $value
} elseif { $param equals "passwd" } {
set tmm_apm_citrix_password $value
} elseif { $param equals "passwd1" } {
set tmm_apm_citrix_password1 $value
HTTP::header replace "username" $tmm_apm_citrix_username
HTTP::header replace "password" $tmm_apm_citrix_password
HTTP::release
} elseif { ($tmm_apm_citrix_pnagent == 1) || ($tmm_apm_citrix_nongateway == 1) } {
if { $tmm_apm_citrix_nongateway == 1 } {
log -noname accesscontrol.local1.debug "01490000<!--:3: Parsing credentials for Citrix PNAgent"-->
if { [regexp -nocase {<username>([^<]+)</username>} $payload dummy tmm_apm_citrix_username] == 0 } {
set tmm_apm_disp_sess_id [string range $tmm_apm_session_id 24 32]
log -noname accesscontrol.local1.error "01490000<!--:3: $tmm_apm_disp_sess_id: Username not found in the PNAgent POST body" -->
return
if { [regexp -nocase {<password>]+>([^<]+)</password>} $payload dummy tmm_apm_citrix_password] == 0 } {
log -noname accesscontrol.local1.error "01490000<!--:3: $tmm_apm_disp_sess_id: Password not found in the PNAgent POST body" -->
return
binary scan $tmm_apm_citrix_password c* pass
set len [llength $pass]
set result {}
for { set i 0 } { $i < $len } { incr i } {
set hi [lindex $pass $i]
set hi [ expr { $hi - 0x41 } ]
set hi [ expr { $hi << 4 } ]
incr i
set lo [lindex $pass $i]
set lo [ expr { $lo - 0x41 } ]
set char [ binary format c [expr {$hi + $lo}] ]
append result $char
binary scan $result H* pass
binary scan $result c* pass
set result {}
set first [lindex $pass 0]
set char [ binary format c [expr { $first ^ 0xA5 } ] ]
append result $char
for { set i 1 } { $i < $len } { incr i } {
set prev [ lindex $pass [expr {$i-1}] ]
set curr [ lindex $pass $i ]
set char [ binary format c [ expr {$curr ^ $prev ^ 0xA5} ] ]
append result $char
set tmm_apm_citrix_password [ regsub -all {\000} $result {} ]
HTTP::release
when HTTP_RESPONSE {
if { [HTTP::header Content-Type] contains "application/x-ica" } {
set tmm_apm_citrix_ica_patching 1
when HTTP_RESPONSE_DATA {
if { $tmm_apm_citrix_ica_patching == 1 } {
log -noname accesscontrol.local1.debug "01490000<!--:3: ICA file patching"-->
set payload [ regsub -all {Proxy[^\n]+\n} $payload {} ]
set payload [ regsub {DoNotUseDefaultCSL[^\n]+\n} $payload {} ]
set payload [ regsub {CGPAddress[^\n]+\n} $payload {} ]
regexp -line {Address=(.+)} $payload dummy CtxAddrPort
set CtxAddr [lindex [split $CtxAddrPort ":"] 0]
set CtxPort [lindex [split $CtxAddrPort ":"] 1]
regexp -line {CGPAddress=(.+)} $payload dummy CGPAddrPort
if { [info exists CGPAddrPort] } {
set CtxPort [lindex [split $CGPAddrPort ":"] 1]
set payload [ regsub {\[WFClient\]} $payload "&\r\nProxyType=Secure\r\nProxyUseFQDN=On\r\nProxyHost=$tmm_apm_vip\r\nProxyUsername=$tmm_apm_session_id\r\nProxyPassword=$CtxAddr-$CtxPort" ]
set payload [ regsub {SSLEnable[^\n]+\n} $payload "SSLEnable=On\r\n" ]
set payload [ regsub {Address[^\n]+\n} $payload "Address=$tmm_apm_host\r\nHTTPBrowserAddress=!\r\n" ]
HTTP::respond 200 content $payload Content-Type [HTTP::header Content-Type]
when ACCESS_SESSION_STARTED {
if { ($tmm_apm_citrix_receiver == 0) or ![info exists tmm_apm_citrix_password1] } {
return
ACCESS::session data set "session.logon.last.password1" [URI::decode $tmm_apm_citrix_password1]
when ACCESS_POLICY_COMPLETED {
if { $tmm_apm_citrix_receiver == 0 } {
return
set sid [ACCESS::session data get session.keydb]
set result [ACCESS::policy result]
if { [info exists tmm_apm_citrix_username] } {
unset tmm_apm_citrix_username
if { [info exists tmm_apm_citrix_password] } {
unset tmm_apm_citrix_password
if { [info exists tmm_apm_citrix_password1] } {
unset tmm_apm_citrix_password1
ACCESS::session data set "session.logon.last.password1" ""
if { $result equals "allow" } {
set resp "<meta http-equiv='\"REFRESH\"' content='\"0;' url='$::tmm_apm_pnagent_url\"'>"
ACCESS::respond 200 content $resp Set-Cookie "MRHSession=$sid;path=/;secure" Set-Cookie "NSC_AAAC=123;path=/;secure"
