Problem this snippet solves:
With the combination of BIG-IP Access Policy Manager (APM) and Citrix XenApp, organizations can deliver a complete remote access solution that allows for scalability, security, compliance and flexibility.
This iRule comprises the second part of two iRules that are part of the Citrix Secure Access deployment. The complete installation instructions for this setup will be located in the solutions section of F5.com shortly.
With this iRule, users can connect using BIG-IP APM’s secure proxy mode, allowing for connections to XenApp from a variety of clients including Citrix Receiver, PN Agent and Dazzle.
Code :
when CLIENT_ACCEPTED {
TCP::collect 7
when CLIENT_DATA {
if { [TCP::payload 7] equals "CONNECT" } {
SSL::disable
TCP::release
if { [HTTP::method] equals "CONNECT" } {
set authstr [HTTP::header Proxy-Authorization]
set authstr [lindex [ split $authstr " " ] 1 ]
set remainder [ lindex [split [expr [string length $authstr] / 4.0 ] "." ] 1 ]
if { $remainder != "0" } {
if { [regsub -all {(A=)} $authstr = newstring] > 0 } {
set authstr $newstring
set authstr [b64decode $authstr]
set tmm_apm_disp_sess_id [string range [lindex [split $authstr ":"] 0] 24 32]
set authstr [ lindex [ split $authstr ":" ] 1 ]
set ipport [split $authstr "-" ]
set ip [ lindex $ipport 0 ]
set port [ lindex $ipport 1 ]
if { [matchclass CitrixAppServers equals "$ip-$port"] == 0 } {
log -noname accesscontrol.local1.error "01490000<!--:3: $tmm_apm_disp_sess_id: Invalid IP and Port $ip-$port in CONNECT from IP [IP::client_addr]"-->
reject
return
node $ip $port
TCP::respond "HTTP/1.0 200 Connection established\r\n\r\n"
HTTP::disable discard
SSL::enable
SSL::collect
when CLIENTSSL_DATA {
binary scan [SSL::payload] c socksver
if { $socksver != 5 } {
SSL::release
return
SSL::payload replace 0 [SSL::payload length] {}
if { [info exists socks_connect] } {
SSL::respond [binary format H2H2H2H2H2H2H2H2H2H2 05 00 00 01 00 00 00 00 00 00]
SSL::release
set socks_connect {}
SSL::respond [binary format H2H2 05 00]
SSL::collect
