Has anyone customised their citrix remote desktop icons on 11.2 when using direct access to an XML Broker rather than a citrix web interface?
CWI puts proper windows icons on everything. My users are complaining because of the generic application icons served up (Admittedly, they have a point. It’s a lot harder trying to find an app on the F5 remote desktop rather than the citrix web interface one).
Looking through the icons available in the customisation, APM only has one generic application icon defined, which is the one used… And yes, it’s browser independent as you’d expect.
I have seen this. I am pretty sure, at least with 11.1, the APM only supported 32x32 32bpp icons. Check the icons and see. The client I was working with had to modify some of their icons on the XMLB Side.
It kind of looks like a bug… Looking deeper into the tcp stream between the BigIP APM and the XMLBroker, and I see 3 requests for icon data. One for Adobe Reader (Works), one for a remote desktop something (Works), and one for Calculator (I get a lot of icon data back, but no icon shown).
After the calculator, there’s no more icon data requested from the XMLBroker…
This is running 11.2HF2 (HF2 had a fix in there for not displaying icons… I wonder if it wasn’t quite fixed properly).
What version of XenApp are you using? Sounds like you have gathered a lot of troubleshooting data already - it would be great if you can open a case, and F5 support can then help you resolve this issue.
Case opened today. First response is known problem, upgrade to HF2… Sadly for support, I’m already at HF2 So hopefully they’ll read the tcpdump I gave them and come up with a solution. Funnily enough, the bpp=4 icons work.. The 32bpp icon of the Calculator app is what seems to brake it.
I also found another hit in a SOL note regarding XenApp 4.5… (WHich we’re running). It has a work-around that relies on a registry change and a reboot. Our Citrix admin is going to do that for me tonite on a test server and we’ll see how that goes. The SOL note says it’s something to do with chunking of the icon data and not sticking to RFC specs quite close enough (Is there an IBM engineer in there somewhere? They used to have issues where sent data wasn’t quite RFC compliant in products where others took it fine - e.g. Multicast in AIX
Was the XenApp bug in 4.5… The work-around originally killed the test xenapp server, but the admins fixed that, and I have icons again. Much nicer… Would be nice if APM didn’t freak for a single bad response and disable ALL subsequent icons though…
I’ve been playing around to try & fixup the stream on the internal BigIP VS (Running two layer as in the whitepaper), but no luck so far (The explanation for headers given doesn’t seem to jive… Because if you fixup the headers, it still doesn’t work without the xenapp server work-around. Does APM just have issues with chunked icon data? Because the workaround only seems to stop the chunking. not change any headers).
There are two issues that cause the problem with XenApp 4.5
The response from 4.5 XML broker violates HTTP standard in two ways:
1) It has ‘Transfer-Coding’ header instead of ‘Transfer-Encoding’ <-- this one is easy to fix with iRules
2) It does not have a trailing CRLF as dictated by RFC. <-- this one is not so easy and requires layered virtuals and non-the-shortest iRule to fix - so getting it done on the XenApp server itself is the best way to go.
Do you know exactly where the trailing CRLF is missing from? (A glutton for punishment, me) As you say, fixing the headers is easy. But I can’t actually find where there’s any missing CRLF’s in the icondata response (Looking at the one that is requested by not displayed).
Although the work-around does work, the description of it is actually not a 100% match. The SOL note mentions missing apps… but all the apps are there on mine. It’s just the icons that are missing. Three are requested and display correctly. The third is requested, and returned, but not displayed. APM then doesn’t bother to request any more icons. It’s a bit strange to me that APM just gives up at that point, rather than requesting the NEXT icon.
I’ve also noticed that when it does work with the work-around in place on the XMLBroker, the icon display is pretty slow… The remote desktop comes up first with generic icons. Then the icons are gradually refreshed one by one. At about 3-4 icons per second. On a desktop with about 50 icons, that can get annoying (Especially with users… They want the world
Looking deeper into the slowness of the icon updates… Firebug shows an 8 second login time (That could be the XMLBroker, it’s pointing at a single test server until the admins can do the registry workaround on the production servers) followed by the icons being requested one by one… Trouble is, they’re all requested using POST… Which isn’t going to be cached… (And cache-control explicitly says no-cache!)
So why are the icons pulled using POST? (I’m running through the .js now to try & find the offending code and see if it can use a GET and take advantage of caching. Although I suspect the over-use of the same URI for every request is going to kill that)
Sigh… Refreshing the page also pops up the login requester…
Because CitrixPackageManager.state isn’t being set… Because it’s null, the javascript doesn’t think the remotedesktop was finished… So it popups up the login requester again…
I don’t believe there is any other way to communicate with the XML broker other than the POST commands. Since every request to the XML broker has to be authenticated, and there are no cookies used, etc. they all have to be POST. We are looking into improving icons cacheability and performance on the webtop though.
Improvement would be good. Having the JavaScript on the client query icons in parallel and prioritising icons actually in view would be a good start…
In our setup, there’s 13 folders and 11 apps in view… Unfortunately APM downloads the icons for the apps in the folders first. Which means you sit & watch default icons for about 20 seconds before the 11 visible apps update 1 at a time (Over 3-4 seconds more). If the VISIBLE icons were updated FIRST you wouldn’t notice the apps in folders hadn’t been updated yet because they’re not yet visible.
Strange that the XML-Broker only accepts POST… Since there’s no real difference betwen POST and GET except GET’s can usually be cached and POST’s almost always can’t.
Thanks for the suggestion, I see your point. Feel free to request F5 Support to provide a fix for ID399148.
I agree that the current implementation for icon handling is far from ideal but this is what will be definitely improved. All icons will be requested as normal images, thus in most cases they will be served from the local browser cache.
I’ve never seen this before. I refresh the Webtop page, and it works just fine. Could you please elaborate? Looks like a bug…
Another known issue? or local config problem?
Hello Hamish,
It has nothing to do with CitrixPackageManager.state. The reason you’re getting logon dialog is because … you refreshed the page.
Since we’re not caching Citrix credentials of a user, then we can’t show you apps afrer you do the refresh.
