Cisco GSLB workig with LTM
All,
Due to the recent daylight savings time “DST” issues we were upgrading to 9.4 code on the LTMs. What I saw was my script to utilize the GSLB keep alive to determine if it should fail over did not work on this version of code. I was wondering if anyone has seen this issue or actually over come it on 9.4? Below is my script for review.. I was wondering if I was doing anything wrong here?
Mike
when CLIENT_ACCEPTED {
if { [active_members pool] == 0 } {
discard
Other than the fact that you don’t need two equals signs in TCL since variables are set explicitly, not implicitly, everything looks fine there.
If you’re experiencing problems still, I’d try adding a log statement above the if line to log what the active_members command is returning so you can see a little more about what’s going on.
Colin
