Cisco ACE probe to F5 Load Balancer Monitor
I have a (another) probe from our Cisco ACE Load Balancer that I am trying to convert to an F5 Monitor. Again, I understand the interval, faildetect, etc. I don’t know how to convert is the “ip address 192.168.33.207 routed”
Below is the probe syntax from the Cisco ACE Load Balancer
probe tcp PHOTOS
  interval 10
  faildetect 2
  passdetect interval 10
  open 3
MJ
I believe that the “ip address x.x.x.x routed” would probably map to “Alias Address” field in the tcp monitor configuration screen.
Thanks. That was one of my first thoughts too, but when I configure monitor that way it causes the member to fails.
Have you tried reviewing the Cisco documentation on this? Configuring the Destination IP Address . It does appear that the configuration is similar to the “Alias Address” field from what I read about it.
